Correct stud distance
31 May 2007
Hi guys
Whats the correct stud distance for 1220x600 9.5mm plasterboard?
Cheers
wow.. small sheets..
what are you boarding?
centers are usually either 450 or 600 depending on board width ( 600, 900, 1200 wide etc.. )
Thanks for the reply
450 it is
Its a small outroom and the big sheets wont fit the car :) and I cant wait for delivery.
once again thank you
If you haven't already bought them, I recommend you use 12.5 mm
The centres for 2400x1200mm boards are 400 centres allow for your boards that either start or run into your corners....
Not 1200 boards...... :wink:
If it's a wall, always use 12.5m boards; & buy full size 2.4m x 1.2m boards, even if you have to cut them, it's much cheaper. :wink:
Stud spacing @ 400 virtical as stated but you also need intermediate noggins at 1200mm.
1800mm long boards - 450mm c/c.
2400mm long boards - 40mm c/c.
I would never use 600mm centre spacing and would never use 9.5mm boards. The two together would be fatal. :P
