All the more reason for him to stay on good terms with everybody and cooperate. As there are half a dozen parties involved, it will be extremely difficult, timeconsuming and costly for him to get it changed the hard way. If he can force the issue at all; by accepting the existing situation for years, he probably created quid pro quo consent.see my previous post...he wants the pipe orf his land!!!!
Norcon..so shall I hire an excavator and start digging up the tarmac road next to my house which is where the landowner wants me to put it? I am sure the Highways Authorities
The supplier is only responsible up to the stop at the end of the communication pipe
If its a public highway and you're not prepared to dig the trench then its up to the water authority involved.
Yes I know.
Therefore if he has damaged the supply he is responsible for the repair
He has repaired the pipe but the OP is now kicking up a fuss about how he has repaired it and wants the farmer to relay the pipe at his expense.
The farmer now wants the pipe removed.
result = stalemate
The farmer has made an above ground repair, clearly unacceptable as even you may agree.
The pipe is legally installed in the landowners field, if the farmer want's it moved then he has to pay the cost
result = stalemate
A plough ripped it up so a spade will dig a small trench to lower it.
Will hardly cost thousands to do this. The OP could have it done in the time he has spent on this forum.
The farmer has no legal obligation what so ever to relay the pipe at his cost in this inatance.
If it is causing an obstruction in his field (which it clearly is) then he can rip it out. It would be a danger to horses and other livestock and I would rip it out asap.
of facing a very expensive repair because someone has damaged "your property".
No he can not, not legally that is.If it is causing an obstruction in his field (which it clearly is) then he can rip it out. .
