Hi there, I changed a standard ceiling rose light with a spotlight and all was well, light turned on and off, dimmed correctly etc. However, after a while of running (couple of hours) the light went out. When I went and looked it was very hot and after it cooled down I took it apart and found the innards were melted although the wiring itself was perfectly intact.
The wires coming from the wall are:
3 red wires
3 green and yellow wires
2 black wires
1 black wire with a small amount of red sheath on it (I assume it is the switch)
I wired this up by joining all the red wires together but did not connect them to the spotlight as I assumed these were the loop.
I wired the 2 black wires together and connected them to the blue wire on the spotlight.
I wired the 3 green and yellow together and connected them to the green and yellow on the spotlight.
I wired the 1 black wire with the red sheath to the brown wire on the spotlight.
Did I wire the light up incorrectly? If not then does anybody have any idea why it would have melted?
Thanks in advance for your help.
3 red wires
2 black wires
