sleeving colour
15 Nov 2005
South
Cook Islands
I observe that the electrician :shock: who connected the control systems on my gas boiler has used 3-core flex instead of 3+E or Boiler cable
he has used the G/Y core for signalling :x not as a CPC
(CPC is present on a single core)
I think I will put heat-shrink sleeving on the G&Y that is not CPC
the other cores are blue and brown, what is the conventional colour I should use for the third core?
Call him back & politely but firmly request that the installation is made compliant.
I don't want him back. It took him several attempts to get it working.
It was done over a year ago and I have given up with the installing company.
Replace the cable?
The official colour for a phase is brown so even if you end up with brown, black, grey, blue you need to ID the cables correctly.
what colour is 3+E these days? I used to have red/yellow/blue
Brown, black, grey usually.
You'd need to sleeve the black with brown sleeving and grey with blue sleeving.
Can't I just sleeve the G&Y with grey? The flex he has used has Brown, Blue, Green/yellow cores.
I think if I do re-cable it (I probably won't) I'd get some 12-core or whatever it is boilers use. He has three 3-core flex and one 3+E going in the duct from the boiler, up to a wiring centre in the airing cupboard on the next floor, where there is 1x Cyl stat, 1x pump, 1x 3Port valve.
I could do it myself, but can I be bothered taking the floor up?
Grey isn't the colour to use as a phase in a single phase installation, it is brown.
Personally I wouldn't, it is shoddy workmanship.
Can you use the existing cable as a pull wire?
Shoot the idiot!
G/Y is only EVER allowed to be a CPC/Earth
Does that not refer to the colour, or with Single core G/Y cable.
Not that I would do it, but I read the regs,That you can colour oversleeve the core in flex or multicore, but not number it.
not easily :( it goes from the boiler connection block into a duct, up one floor, through some joists under the bathroom floor, through wall, up through floor of airing cupboard, into wiring centre.
If I verify which G/Y cores are L or S/L, and sleeve them in brown at each end, that would at least be an improvement, wouldn't it?
That refers to colour. The inner core of a T&E is single insulated hence must not be used as a live conductor, however as JD stated it was flex I assumed it was G/Y sheathed.
Nah, still poo workmanship. You'll never change my mind on that one :wink:
no, I meant it was 3-core flex, with brown/blue/green&yellow cores, and white oversheath
