Hi All,
Very new to this site and have been reading through several articles after searching on Google for information relating to changing a central heating pump and use of inhibitors and the like.
Really impressed with the wealth of knowledge on here so I thought I'd join and jump in!
The heating system in my house probably dates back to the 1960's. I know that the current boiler, a wonderfully rattley and noisy Potterton Netaheat MkII F was installed in 1983/84 as was the Grundfos 15-50 pump which gave up the ghost sometime between April and now.
I have managed to buy a 3 month old 15-60 pump from a plumber mate for £10 so that's great news.
I have also managed to pick his brain on how to drain down and read about this on the internet also.
I ended up improvising tools and bits to drain down the central heating system.
Now I am ready to go the local Plumbers' merchants and buy a few goodies. Firstly, a draincock for the central heating as I cannot find any on any of the radiators and secondly, some Fernox but not without some good advice form you guys please!!!
I have been reading about Fernox Restorer and wondered what to use. The system consists normal bore pipework, steel radiators, one which leaked a few years ago and now remains switched off!
I have 16 double radiators in the house not all are in use or accessible. Some have been taken off for restoration work and not been put back on so I assume they are currently out of the equation for the time being.
I was wondering how much Restorer to use, if any, and how much inhibitor to use. I am assuming that the use of restorers, at least Heavy Duty ones, is not necessarily a good thing as I wouldn't want to open up a 'can of worms'.
Money is tight at the moment hence having to undertake the job myself.
For today though, I am very impressed so far that I have managed to remove the pump and drain the system down but not in that order. Although plumbing is allegedly logical, sometimes it escapes me hence never having really delved into it.
One other thing is that I had to strip down the Potterton EP2001 controller as it started adjusting itself when a lot of water got onto it. That is currently being 'hair-dried' so hopefully no permanent damage.
Before I drained the system down, I turned off the valves either side of the pump but I fear that they are 'passing'. Should I change these or live with them.
Once I have a draincock installed, I would be fairly happy to tinker with anything else that rears its ugly head.
Your professional advice would be greatly appreciated.
Regards,
Roge
Regards,
Roge
