about 2 metres and one shed is about 2.5 metres high.
The cheapest way would be to use a competent electrician, as he will already own the several hundred pounds worth of test equipment needed to ensure a safe job, which means you wouldn't have to buy it.what would be the cheapest and safest way of doing this?
Yes.i now know that cable's must be over 3.5m high if they are to be run between buildings
What you asked was:i was just asking for peoples opinion
So since you mentioned safety, I took it that you were interested in safety.I need to run some cable between 2 sheds to supply a consumer unit, what would be the cheapest and safest way of doing this? Preferably over head.
Just WTF do you get the idea that it's OK to abuse people because you didn't happen to like the advice they gave you, even when it was a civil, complete and valid answer to your question?ban all sheds you really are a t****r.
And what's wrong with that?I apologise if i've cause offence but ive come on here asking for advice to install a sub main and all you've done is tell me to get a competent electrician
There is.and then in your next post imply that there is other stuff i need to know.
1) I didn't go looking at his previous posts.
I've recently changed a consumer unit at a persons house and when i turned it on it began tripping the rcd. So now i've taken out the main rcd and moved them onto rcbo's and told the owner that i will sort out the circuits that are tripping. Now i know that with the current regs everything must be on an rcd but because i've changed it over is there anyway around not putting certain circuits on an rcd because i know that there's a fault on the cooker itself that is making the rcd trip not the circuit and also it will save him money and myself hassle if i don't have to go around and either find the faults or re-wire new circuits.
Many, many, many. And anyway i'm only young too.You both must've made mistakes in your careers?
I have no problem - was just suprised at the random outburst after asking for help on here before! Apologies if I caused any offence.Don't really no what bongos problem is, as the first of those jobs has been rectified and the second was never a problem anyway.
