OK knowledgeable folks, I realise there are other posts on almost this topic but none seem to answer the question directly. I have bought some fire rated Mr16 recessed halogen downlights but have since discovered that the ceiling void they are to be installed into is not deep enough for what I presume is heat venting. I was considering just changing the halogen bulbs over to equivalent LED ones (i.e Much less heat buildup). Each lamp has its own transformer attached so can I theoretically swap them straight over ?? Assuming that the LED's are 12V ones
Very much look forward to your comments.
Cheers
Raveboy
Cheers
Raveboy
