Replacing MR16 Halogens with equivalent LED's
11 Nov 2009
Isle of Wight
OK knowledgeable folks, I realise there are other posts on almost this topic but none seem to answer the question directly. I have bought some fire rated Mr16 recessed halogen downlights but have since discovered that the ceiling void they are to be installed into is not deep enough for what I presume is heat venting. I was considering just changing the halogen bulbs over to equivalent LED ones (i.e Much less heat buildup). Each lamp has its own transformer attached so can I theoretically swap them straight over ?? Assuming that the LED's are 12V ones
Very much look forward to your comments.
Cheers
Raveboy
30 Jul 2006
Hampshire
What happens when someone else comes along, and seeing fittings rated for 50 Watt halogen lamps, replaces your LEDs with halogen lamps?
11 Nov 2009
Isle of Wight
Ahh yes I see your point - Tricky situation. Doe's anyone have any suggestions for how to get around this lack of ceiling depth problem for halogen spot mounting ?? My major concern is the heat build-up underneath the first floor floorboards which is why I thought of the LED route
11 Nov 2009
Isle of Wight
Hi Sparkwright, The void is about 125mm and the instructions say that the minimum should be 135mm. The actual units that I have are only about 110mm high but I guess they are allowing for breathing space above the lamp? No holes have been cut yet
Cheers
20 Aug 2009
Dorset
it is usual to leave a minimum void of 100 mm for downlighters, at least it used to be.
you could possibly get away with fitting the lights, but of course it is quite right to obey the manufacturers instructions, especially with the risk of fire in mind.
have you considered a different make/design of downlighter which may not require such a deep void?
15 Feb 2007
Derbyshire
Then the solution is simple - don't cut holes, and install lighting which actually works.
Did you not read my reply to your 1 millionth tedious remark to another recent question about installing downlighters? I assume it didnt go in so I will repeat - some people like downlighters. The next time someone asks a question about downlighters do us all a favour and go to the pub instead, you total total bore.
27 Aug 2003
London
Yup.
No point you repeating it - I'm not going to take any more notice this time of you thinking you can tell me what I may or may not say here than I did last time.
Which was:
absolutely no notice at all.
The world is full of people who like inappropriate things.
22 Jan 2008
So, BAS. Who appointed you chief arbiter of what is and isn't appropriate?
Some people like downlighters and the lighting effect they produce - what gives you the right to declare them wrong? While you do give some sound advice (for an armchair electrician), you also come across as a pompous and pedantic bore.
Try practicing some of the tolerance you preach on other subjects.
To the OP, have a look on the TLC site - they have downlighters that will fit a void as small as 100mm.
27 Aug 2003
London
Me.
I have the right to make what I consider to be appropriate suggestions, and I shall exercise that right.
If we all adopted your fatuous approach then nothing anybody ever asked about or described here would ever be declared wrong.
What give me the right is people coming here and asking me questions.
Why don't you just phone RichThompson so you can whinge at each other?
11 Nov 2009
Isle of Wight
Thanks Tonka - I'll check out TLC. I've also since discovered that if I put aluminium reflector bulbs in they direct the heat outwards as opposed to back into the light so I may be able to get away with a smaller void (Especially as the void is ventilated anyway. Cheers for all you comments people
