Dowlights and ceiling Insulation
6 Jul 2008
Lancashire
Hi There
After many months I have finished the outside of my double dorma extension. I am now ready to install the celotex in the ceiling and dorma frame.
I am installing 100mm celotex between ceiling joists and 30mm below the joists. The ceiling height is very low ... too low to install ceiling light fittings without issuing hard hats to the occupants. I would assume that the Building Inspector would frown upon downlights on the grounds of fire safety and the fact that the integrity of the insulation would be damaged. Your thoughts /Advice would be welcome
Thanks for your help
Downlighters in celotex will result in a melted mess.
Although LED types would not cause melting, as you correctly state, it would compromise the insulation.
Wall lights would be one solution.
He certainly will.
I'm surprised though that he didn't frown on a ceiling so low that you can't have suspended lights.
