Having been on the Chelmer site again, it's very vague with regard to full performance specs.
another doc drivel alias
Funnily enough, that's what was said when I posted about fitting a store in my house last year. Actually, not that funny, or helpful, but nice try anyway.
If you click on my profile, or name, or something, you can get thru eventually to my album, with pics with my boiler and store. It does exist. Really.
Main reasons for ME choosing a thermal store as opposed to a hot water cylinder....
1 – I wanted solar, wood burner and gas - all able to heat rads AND hot water.
2 - no loft or room for header tanks etc - so I had a straight choice between an unvented cylinder or what I chose...
3 - hey, it's different, it’s the future, it’s rubbish, it’s 'not as good as an unvented cylinder', whatever. But it works great.
4 – excellent hot water – biiiiig shower with rain effect head and bodyjets.
5 - loads cheaper than a quote I got for an OSO unvented and accumulator package. And I mean LOADS. I’ve got secondhand solar, a 10 kw stove, a 300l store and a new Vaillant condenser for the same £. No contest.
CMJ - as you're not going to take the store out, you need to get it to work properly.
‘Chucking in an unvented’ may have been a better option to start with, as you don’t need the multiple energy source capabilities of a store, but ufh companies (eg nuheat again) DO use thermal stores in their installs – there must be a reason for that?
As I've said, I'm not a plumber, but feel 'qualified' to answer on the basis that I've got a store. Nothing more than that.
So, your points..from a layman’s point of view…
1 and 2 – if the store has it’s own ‘bubble’ is it like a megaflop? – they can ‘lose’ their bubble and have to it get re-charged with a bicycle pump I believe. If yours can lose the air, you need expansion volume elsewhere to compensate and make everything safe.
3 – you need to nail the Chelmer guy down and get actual, proper performance figures.
That would be cold water temp in vs hot water temp out at x degrees at y litres a minute based on store temperatures of x,y and z degrees. Without knowing the temperature rise per litres a minute you can achieve at various store temps, you don’t know if you can turn your boiler down.
You’ve got, and I quote, ‘a patented high performance tristage monopath coil heat exchanger’. It sounds technical, but it’s probably a ribbed coil of copper pipe.
With a plate heat exchanger you can be within a few degrees of your desired water temp if it’s sized right – I can shower in the summer in, what, 45 degree water with a store at 50-55.
If I got a bigger heat exchanger, the theory is I could still do that with mains water near freezing.
That’s theory anyway – as it stands I need the store over 70 in the dead of winter. Very generally, coils are crap in comparison – but only from what I’ve read.
If your coil is as spangly and clever as the name suggests, it should be pretty good.
If not, you might have to look at altering things – have a look at nuheat or dps websites to see their plate heat exchanger diagrams – you might be able to retro fit an external one with a shunt pump and flowswitch using the existing tappings on your store – a plumber needs to look at that and advise. A more knowledgeable one obviously, not the one you’ve had.
6 – I have temp gauges all over mine, total of six I think, so we can see what’s going on. We thought that fault-finding would be a real p.i.t.a with no information.
Re the pumps and valves – yes, I reckon each zone or user should have a valve! Whether you need one pump per zone valve, or just the one pump that then tees off to all the zone valves I don’t know – you need a plumber to look at the loads and size the pump(s) correctly.
I have one pump that does two zones (will eventually be four zones here), each zone has it’s own 2 port valve. So all users have the one pump, plus I have one built-in in the boiler obviously.
If your boiler is heating your rads when it’s supposed to be doing the store, no wonder the hot water is marginal.
Magnaclean – yes, or spiroclean, probably the same thing. Something anyway!
Inhibitor – loads! If you’re in a hard water area (I’m not) scale will be a problem as said above. Whether inhibitor prevents scale I don’t know – but it’s something that needs looking at because with the higher temps a store runs at compared to a cylinder, scale buildup and reduction in performance will be quicker, especially around the hot water generation bits. Don’t know much about scale, just what I’ve read.
Don’t rip it out – it just needs someone knowledgeable to work on it – that’s the battle, finding someone. My guy is nuheat-approved – might be worth asking them if they have anyone good local to you.
