E
eddiescully
Will need a new oil line from oil pump to ram also NO? or can it be reshaped without kinking it trying to bend it into the new port.
Please excuse me i am rapidy approching the Big 50 so Senior moments are becomeing more frequent!![]()
I agree with boilerman2 remove the ram and get a riello blanking screw and lock the air damper in position thats what i do anyway. Not worth a f**k replacing![]()
Later versions of burner have the adjustment under the shutter but earlier ones the shutter IS the adjustment.Why lock the air damper?
Just remove it a sling it in the bin. You still have the air adjustment slide to adjust the CO2%
Thanks for the advice, I like bypassing things.The brass nut on the ram is difficult to remove (surprising considering how much oil is on the inside).I am tempted to crimp the tube rather than blank it off - is this a dumb idea ?
You are all lazy ba$tids.
It takes less than 5 minutes to change, and I make £17 profit on one.
They generally last 2-3 years at least.
I hope you dont remove parts from gas burners just because you can't be ar$ed to change them!
