Dimmer switch on cabinet lighting
Hey don't be offensive!
I was trying to point out the ambiguity of the wording in the Approved Document, which uses undefined terms and which makes Part P so useless.
Take a fridge or dishwasher a 'brown goods' integrated version usually has a tab which you screw to the underside of the work top, a 'white goods' version just sits under the work top with no attachment. One could be deemed fixed one not, both plug into the same socket both are electrically identical. Hence nonsense.
Same with the lighting a CE marked transformer and lights may come bare or with a mains plug (not the plug and socket connectors which daisy chain the things together). The approved document doesn't mention the mains plug just the connection point.
If I have a table lamp in my kitchen and I stick it down with some Blu-Tac to stop it moving does it become fixed and notifiable?
It is open to interpretation without greater definition of terms, which is what I was pointing out.
Some times a little common sense and pragmatism is required in the application of regulations.
If you think they are undefined then get one of these:
(Other dictionaries are available)
Useless?
There is much about it which makes it useless in practice, but little (if anything) stems from it using normal, common English words without explicitly defining them.
One is fixed, the other is not.
Maybe, but perfectly easy to understand.
If you cut the plug off does the item still comply with the standards which it originally did, and which meant it could carry a CE mark?
Why not try reading the Building Regulations instead?
Possibly.
Would you be happier to consider things on the basis of whether they are designed to be fixed?
So why are you abandoning all common sense and claiming that you don't know what "fixed" means?
Just to let you know the cabinets are in the living room and are free standing, not fixed to any structure in the property.
The plugs were not cut off, they were taken off with a screwdriver and the ends fixed to connectors within the switch, the cable was not cut at any time.
Not one to fan the fan the flames of an arguement but thought that you should know.
But the lights are fixed to them, and presumably are designed to be fixed to something?
But as it's a living room they aren't notifiable in any event.
I guess we all assumed that because it's very rare for things to come with rewireable plugs on these days, as fitting them in the factory can't be automated.
