D
dextrous
Think I want a job with transco if the job involves going round to people's houses, shaking your head saying carp job and turning off the valve.
8mm over 3 meters will be enough for between 7-8KW,more than ample for a standad 4 ring hob.
Are you sure? Have you tried it? Next time you fit a fire try it. I fitted a fire using 3m of 8mm pipe. Pressure drop well exceeded 1mb
By the way, a hob is around 12kW. More if it is 5 ring jobby
]Oh, the joy of seeing people sad, hopefully some crying kids with their XMas ruined. Just the power of knowing that 5 minutes of my time could solve all that, and the warm glow within knowing that I have refused to give it.
Never Said Owt About Making People Sad On Xmas day, Why Should We Fix Other Peoples Bad WorkManship , It Aint Grid job To Repair It , They Are Tolf Not To Touch, It Aint The Gas Board No More Pal
and when the tofo guy fixes it, he needs to check MI, ventilation gas supply pipe etc etc then get the blame for all the faults
Dextrous It Must Be lovely To Work For Love
I'm surprised you're on here - giving out all this help and advice for free.
Im Not Clever Enough To Give Advice I Only ToFo . if Any Body Wants Out Fixing For Free Cos itl Only Take 5 Mins Ill make Sure I Give Them you're Name
Now that I can understand. Not doing someone a favour while you're already there and have identified the fault, I can't.actualy trasco have diffrent set acs quals to us so i do`nt think they be insured to do any work on restoring a supply to a cooker
Either luckily or otherwise, it's not happened to me, yetI Will Sleep Very Well Its Not That Im Orrible Its Becouse Ive Learnt The Hard Way Not To Do Favours Cos Itl Bit You On The a**e
Anyway, that aside, any chance you could stop beginning every word you type with a capital letter? No Hows That For You
