It's a bit NSFW, but not ever so, and passed a virus check before I uploaded it. And I've had it for years - never seemed to do anything bad.I am way too scared to download that file xmas_girl.exe.
I really don't think that will be the case. There has never been a tradition of forcing all existing installations to be updated to compliance with a new edition of the wiring regs, and they aren't going to start now.If you base your radial designs on the BS 1363 standard socket outlet you will soon have to change them. These will follow ring mains out the door at break neck speed. You will be left with an unfused outlet and similar restrictions to those used in other EU states.
consistant rules for color coding on portable appliances allow the same appliances to be sold throughout the EU and reduce the risk of people getting shocks when they change the plugs on appliances they grey import themselves (I've heard old stories of people importing equipment where red was earth from germany to the UK and getting shocks)If you need an example look at cable colour coding - what purpose does it serve?
It seems europe in general is trending towards using the german and french systems along with a hybrid plug that fits both (and for small appliances the europlug).if they do change, it will be to a new design that does not benefit any country
Having colors for fixed installations the same as portable appliances makes sense because cable types primerally designed for portable appliances (flex) often have uses within fixed installations.
Amendment No. 2:2004 implements the changes to the identification of cores by colours, in accordance with HD 308 S2. The principal identification colours are now:
Single phase — Green-and-yellow (Earth); blue (Neutral); brown (Live).
Three phase — Green-and-yellow (Earth); blue (Neutral); brown, black, grey (Live).
Lose what?We spent 25 years trying to develop an EU Plug and socket. MK even made a mock up of one of the 'final ' candidates - but all to no avail.
This was an EU project but there is a parallel IEC effort based around the commonly used EU plug. The UK always held out for a fused version but we would have little justification without the ring main. We are much weaker now on the international committees and so I fear we would lose in the long run
Are BS EN 60309-2 plugs / sockets not already a Europe wide standard connector?![]()
We managed without a great many things, in all sorts of areas, for many years.We managed without any consistency for years.
Was that, perhaps, because they were inconsistent?The colour coding of flexes had to be changed again in 2004 to bring them into line with the new cable colours.
Anything can be, and often is, cocked-up, but that doesn't necessarily mean the idea was bad - it usually means it was put into practice by tw@s.I only used the example of cable colours to illustrate that IMO harmonization is not always a great benefit. However, that is just my opinion.
Yes, because the increasing amount of thermal insulation in houses is making it harder to achieve an Iz of 20A with 2.5mm².it is also becoming harder to install ring mains
Is it?
