If you have no water in the pump then leave the GV alone for now.
Did you change the pump valves when you changed the pump?
If not start here as they are terrible for sticking closed even though they look open from the outside.
No i didn't change the pump valves but they are not old and knackered and they seemed to open up ok, no problem opening them, but there should be water there unless it is airlocked somewhere? This is why i was there for so long, trying to get water circulating. That would make the boiler cut out wouldn't it? if there is no water circulating? Would it cut out in 20 secs though? Or could it be the gas valve?
How would you know they opened up ok unless you tried them without the pump on.
Pump valves will seem to open ok on the screw or if your lucky on the spindle but will be actually shut tight.
Best course of action would be to drain down and change these!!
To answer your question yes the boiler would overheat and cut out due to lack of water and yes within 20 seconds[/quote]
For all we know,it could be a sealed system. God forbid
