Hello all. New Punto MK1 owner - well, new car owner altogether.
Anyhoo, noticed a rear brake light out today, bought the replacement bulb and removed the cluster. Problem is, the bulb was ok - seems like a wiring problem. First clue was a rolled up bit of fag packet holding the connector in place . So, after cleaning the contacts and checking over the terminal block, I tried the lights and it worked....until I tried to put it back on to the car. At that point, the indicator stopped working too, making a horrible clicking noise.
Took it off again, cleaned all connections/terminal. No joy. Had a bit of a fiddle and found that all lights worked IF the terminal block was only part way inserted ?!? Hence, I suppose, the fag packet I found in there. Replaced this with something more professional (blu-tac), and refitted.
Then the right hand brake light stopped working.
Removed the right cluster, had a look at all connections, removed and reconnected. Now NONE of the right hand lights work !
Please can anybody help?
