new 32A socket
7 Feb 2010
Cambridgeshire
I live in a new house with the electrics completed in 2005. I have a main consumer unit in the house, and a consumer unit in the garage.
The garage CU is connected to the downstairs ring. Can a 30/32A socket be fitted from the garage consumer unit, or will a new ring to be run from the house CU down to the garage?
thanks in advance.
It will require it's own radial circuit from the main house CU.
The other option would be to upgrade the supply to the garage CU and supply the socket from there.
thanks, just what I thought, but wanted to know the answer before thinking about cable runs and getting a quote
cheers
If the wiring to the garage CU is upgraded, could two 32a sockets be run from the Garage CU or is that getting into a serious level of suppy. I'm upgrading my glass kiln and it would be nice to be able to run two kilns now and again!
If the garage submain is fed from a switchfuse which is in turn supplied via henley block direct from the meter, it's possible. Whether or not this would be wise if there are any other large loads in the house that may be used at the same time is another matter.
