has anyone changed a copper central heating manifold
i have a small leak in the main joint of the 28mm pipe where one of the microbore 10mm joins it
i have tried pouring leak fix in the header tank and tried sealing the joint but to no avail
i was thinking of replacing it with a plastic manifold or similar if any is available
do you know if you can replace these
any advice would be appreciated
