ecoTEC pro heating ok hot water none or very cool
4 Mar 2010
Nottinghamshire
hi i have checked boiler for fault code none showing reset to manufacture setting still no joy
only work in sf.h/b mode which is obtained by pressing -/+ together
can only one shed some light on problem
thanks bob
if theres no fault code then it may be something like diverter passing????with heating off turn hot tap on andcheck heating flow pipe 2 see if it gets hot,if it does then diverter passing to heating
unable to turn heating off as there is no programer at mo having a rewire and new kicthen fitted only just started with this problem been in since dec end off.
now i get nothing when _/+ pressed or leds light up i think its going to be a right b**tard it fix bloody merchants lol
thanks for feed back so far going to try latter when heating has cooled down cheers
Isn't there a switch on the boiler that disables the CH ? Perhaps with suns and moons on it?
What occupies the space to the right of the display?
Tony
if you turn the heating temperature controll down to zero this will shut off your heating
just a bit of advice if the boiler is still in warranty should leave it alone and get them it sort it cos all i know is to fit them lol
thanks again
rob
