Fitted a new MEM board today - one of the ones with the high current outgoing ways.
I found the cover a little flexi, and a little tricky to get on to be honest - it is a very tight fit to the MCB's etc.
The guts are good - a good amount of space. The RCBO's I used are the first release which are taller than the next release due imminently. They are going to be marginally taller than a standard MCB.
MCB's sit well on the dinrail and stay straight.
A little tight around the earth bars where the link runs to the case - not sure if this is only on the high current boards or not.
Annoying that the high current outgoing ways start at 80amp - I would have liked to use a couple 63's (although can obviously use these on the standard ways).
A few pics below, click for larger images.
I was rather rushed to get this installed, so it is not the neatest, but is certainly acceptable.
Bloody camera phone doesn't help.
I will let you figure out why the incoming tails look to have been added too late rather than at the start, and why the outgoing submain loops down around the board......
