Some advice would be appreciated on the following:-
Currently, I have 2 switches (georgian brass) controlling 1 light (240W load). I would like to exchange these switches for dimmers. This would have been straightforward until I found that the back boxes are 16mm and as everyone knows dimmers usually require at least 25mm.
Changing the back boxes is not an option as the room has recently been decorated and I'm not going through that misery again!
Consequently, I have been searching high and low to find dimmers that will fit into a 16mm back box. I can find white ones but not georgian brass with the exception of the varilight ones (master/slave). I was told these will fit in a 16mm box but checking on the TLC website it indicates a 25mm box. Being wary of the fact these can reach temperatures of 50 DegC I'm in two minds whether to install these or just give up and live with the current switches as these appear to be the only option.
Steve
Steve
