I have been reading that the old way of loop in out of roses is no longer used for new installs ,loop in and out at switch is now used for new installs.Why is this surely it is more of a pain and not much room for cables behind switches.
If you like, but you might find Switched live and Neutral works better...........there's only 1 x 2 core and earth at the fitting for L and S.L.......
Does anyone use 16mm boxes now?You don't have to use 16mm boxes.
I did use some 16mm backboxes last year before I knew better! Won't be making the same mistake again though. 25mm all the way.Does anyone use 16mm boxes now?
Pretty much useless, as no room for extra connections, flat plate switches won't fit, and neither will dimmers.
Pretty much useless, as no room for extra connections, flat plate switches won't fit, and neither will dimmers.![]()
D'oh. I meant 35mm not 25mm.I always fit 35mm, but then again, I'm not a domestic spark and so don't have to chisel out walls for deep backboxes day-in day-out.
?So what would the wiring set up be at the switch thanks.
The equivalent of what would be at the rose, so if using twin and earth, there would be 3 cables, each containing L/N/E:So what would the wiring set up be at the switch thanks.
