Ok im inexperinced in this job and im looking for all the information i can get to avoid any surprises or pitfalls as im going along.
The ambition for all of this is to finish with my 40" lcd and electric fire flush or sunk into the supporting wall which in attached at the gable end side.
Now upto now my plan is to put either a concrete lintel or steel rsj just about a foot under my ceiling. I plan on drilling 50mm holes every 2 feet and inserting 50mm steel round bar. About 18-20 inches either side i will support with a plank of wood supported either side of the wall by 3 acrowprops each side.
I believe this to known as pining. Now im reasonable comfortable upto this point. I will be from here cutting out a 5ft x 5ft section out of the wall allowing my lcd and electric fire to be sunk flush and inserting wood supports and attaching plasterboard where the lcs and fire seperate.
This is my concern, i need to go into the cavity at least 7" to make the lcd and fire flush. What i know is i have a cavity wall form inside to outside my walls are are 300mm thick.
What i dont know is how deep my cavity wall is and what are the consequences for removing 5ft square section out of my wall. Will this create a problem with damp?
I suppose i could just cut out the section for both lcd and fire and leave the remaining cavity around it would this be a better option.
Thank you for your time.
Cheers
Leigh
Cheers
Leigh
