Hi, I've just moved to a new house (10 years old) and all the electrics look standard by the builder, apart from some downlights in the house.
The problem I have is using the lawnmower or hoover from the plug in the garage trips the MCB, it is fine when using a corded drill though. The lawnmower works fine if plugged into the house sockets.
This is the setup I have.
Main consumer unit in house with a trip switch to garage (120EB6 B20) 20amp i think?
This goes to another smaller consumer unit in the garage with an RCD 100A and 2 mcb's.
MCB1= The sockets which is 606B B6 (6 amp?)
MCB2 = The light which is 616B B16 (16 amp?)
I'm thinking 6amp is too low for the double socket/lawnmower? (I was also going to spur off the double socket for an outside light).
I have checked over the wiring and none of it looks loose. Any help would be really appreciated. I have pictures of inside the garage consumer unit if that is any help.
