How easy is it to cut a masons mitre on a worktop by handsaw,what size handsaw how many teeth and how to set up the joint thanks.
its very easy if
you have a perfect arc when cutting
are able to cut 100% strait
and can do it without chipping
there is possiby 3 or 4 people in the world that could make a living cutting by hand![]()
and i definatly aint one![]()
Gregers how much do you measure in, do you get much chipping of the laminate,has the saw got lots ot teeth per inch thankyou.How easy is it to cut a masons mitre on a worktop by handsaw,what size handsaw how many teeth and how to set up the joint thanks.
its very easy if
i can,
only thing is i do not do the arc, i do a straight mitre using my combination square,normall 22"handsaw,poly glue,biscuits and colorfill jobs a gooden.![]()
So are you saying even yourself would not be able to do it by hand saw?As a professional carpenter and kitchen fitter i'd say dont even go there.
Where are the pics?right ive just loaded up 2 piccys of my worktop,i hope there is enough detail to give you a good idea of what can be achieved by using a hand saw,biscuits,poly glue,colorfil and maybe a block plane.
this was done approx 6 years ago and its 30mm worktop.
let me know what you think of the pics,if there crud ill try and upload from my digi camara rather then my c.rappy phone.
