Please help. Having just completed a full rewire on a 1970s bungalow, it has weird results on the final tests. I am not very technical, but our electrician mate (long time served) who's done the rewire - and his sparky pals - are all at a frustrated loss.
Basically, although individual stretches of wiring are testing fine, once they are linked together the results are failing. Even though EVERYTHING (including gas and water mains) are disconnected - it is still showing live electricity on the circuits. Why? Where can it be coming from?
Also, they tested a bit of the house wall and it was showing a reading of three volts. Surely this should be completely neutral if everything's disconnected.
The earth around the house has tested fine, and the socket components are testing fine. The only thing that hasn't been rewired is the existing burglar alarm. This is disconnected at mains and has reverted to its internal battery back-up.
What's causing this "leakage" of electricity into circuits (it's happening across several) where nothing is connected? Thankyou.
