I'm about to get new Potterton condensing boiler fitted which has a pump over-run feature, basically to take any excess heat away from the boiler after its been switched off from the programmer. Therefore a by-pass valve will need to be fitted after the pump (to the return line) to ensure flow.
The pump is remote from the boiler (airing cupboard), and immediately after the pump (see picture).
Obviously when the system isn't calling for heat from either the DHW or heating side, both 2-way valves will be closed.
So the question is, where should the b-pass go? on the DHW circuit before the solenoid valve, or the heating side, or does it matter? I should mention that the radiators on the heating side all have TRV's except one.
Thanks in advance
Thanks in advance
