So I'm planning to remove the rad in the lounge and also remove the pipes coming into the room from under the stairs. Removing the rad is the easy bit, but I'm not sure how to cut back the pipes without draining the system down.
Both pipes of the rad are spurred off of a another vertical run under the stairs, so my first assumption is that because it's clearly on it's own and not feeding another rad I can just cap the pipes individually once cut close to the spur point.
The actual cutting I was thinking of doing with a pipe freezing kit applied and a good quality push-fit cap for each pipe. That way I should only have the water in the pipes (and the rad of course) to deal with.
Good idea? Thanks in advance.
