- Joined
- 27 Jan 2008
- Messages
- 29,214
- Reaction score
- 3,582
- Location
- Country
I have a Panasonic TX-26LMD70 TV and this is connected to a Sky+ box, a hard-drive/DVD box (Philips DVDR3440), a VCR, and a lap top. Since the other items don’t have HDMI connection options are the two SCART connectors, the Phono plugs, TV coax, and the PC lead.
The VCR very rarely used but the others are in regular use. For some reason I find the two SCART connectors on the Sky+ are not the same I realise one is IN/OUT and other is OUT only but the Hard-drive/DVD on one output will only work if the output is selected after the unit is switched on.
And with the TV we seem to get a ghost image. I have tried all sorts of combinations of leads but the ghost image seems to be there when ever the hard-drive/DVD is used.
On further investigation I realised the faint ghost image is linked to the Freeview signal and if a blank screen is on hard-drive/DVD and I flick between Freeview and AV1 (hard-drive/DVD) this is easy to confirm.
It seems one can use the TV as a Freeview box to record from but without a second TV to monitor the hard-drive/DVD it is not really a useable feature however I can’t find any way to disable the feature.
To cure the problem I have modified a SCART lead by removing one CVBS lead which linked pin 20 to pin 19 and this has in the main removed the problem but the direct picture from Sky+ does not look quite the same as the signal vie hard-drive/DVD.
I also wonder if a similar mod would help the connection between Sky+ and the hard-drive/DVD.
I wonder if anyone can explain how a SCART lead should be modified to make it one way only.
