galaxy engineer code
7 Jul 2010
Hi peeps
i have a galaxy g2-12 system installed at home and we want to add another zone to the system
my man has installed the pir and cable and run it back to the box but we need the code to set up the zone
we phoned the company but the have gone bust i've looked at similar posts but cant find away to get the engineer code
we have the manual as it was left in the box but cant figure out how to get this code
many thanks for any help
gina x
without knowing who installed it the only way i would reccomend is that you contact local SSAIB company to come around and sort the programming out for you.
as he (or she) will have to reset all parameters on your system
ensure that you tell the company that it is a Galaxy as not every company is familiar with this particular panel
email me if you need any further info
as we fit galaxy to all our installations
Hi peeps
gina x
remove mains
remove battery
put a link between 0v and tamper on the siren out pins on the pcb
remove connections to zone 1 (1001)
defeat panel tamper switch, put the end station panel screw in place
then power the panel up bay battery first then mains
enter default code 1234 (or12345)
this should silence the system
then ESC
then enter default engineers code 1122 or 112233 depends on software version
then ENT
enter engineer code again that should default back to factory
BE AWARE BY DOING THIS YOU NOW HAVE TO REPROG THE WHOLE SYSTEM
