I need to sort out my rear fencing and rear gate (backs onto an alley way) - built by previous owner.
Attaching a pic to assist people's understanding:
What I'm giving some thought to is the rear gate and platform and how to attach posts etc (the back gate left post as you look at it is rotten through and no longer in the ground). I want to put the posts in a slightly different location and fit a small side access door.
I've seen a couple of ways of anchoring, firstly just cementing in the posts which will involve creating large holes in the concrete so I was investigating alternatives that may be easier or provide additional support or reduce the chance of rotting.
I've seen cement in a support LINK which will raise the post off the platform (hopefully prevent further rot) or another one which use a bolt down post LINK which is likely to be the easiest solution.
Having not used these supports before, I'm concerned that the bolt down will provide adequate support for such a structure so I would appreciate people's opinions and experiences on that.
I'm also concerned about the level of support provided by the raised type anchor base being sufficient.
Also are there any other obvious solutions which I may be missing?
Thanks!!
Thanks!!
