Bought a new pole switch as the old one only had one earth terminal, hence why I think it was badly twisted together. Trimmed the butchered cabling up and put some sleeving on the earths
Got the 60amp choc blocs (as recommended) and it's a perfect fit to where the original terminal block was fitted.
Sleeved the earth again and I also left about a 0.5m run in the loft, just incase this ever happens again - I won't have to re-run the cable in the wall, just snip the end
All is working fine now, so fingers crossed it stays that way!
Thanks alot for all the help. Very much appreciated
