plug socket
27 Jul 2010
Sussex
It seems my last attempt to post this question did not work. I have above counter switches connected to under counter sockets for my dishwasher/washing machine etc. Can I fit a cooker switch with plug socket attached to the exsisting wiring to control my dishwasher and kettle?
You want to plug your kettle in next to the existing dishwasher switch?
I may not have explained what I want to do very well. I do not want to connect a cooker I just want to use a similar kind of switch, is there such a switch on the market?
Hi Skenk. seems our messages are crossing over. Yes I want to plug my kettle in next to the on/off switch for my dishwasher, but, my wife only wants one switch on the wall
You can either use a cooker control unit, or a dual backox and fit a single socket next to the switch.
Assuming the feed to the switch isn't a spur of course.
Either way, you will need to chop the wall out to accommodate either a double or dual box. Make sure the switch you buy isn't marked 'cooker' as this would be misleading (really it should be marked dishwasher). As Loverocket says, you can only do this if the circuit is suitable.
I think I can see what you are trying to do, but its a cack-handed way of doing it.
You would need to find a cooker switch that does not actually say "cooker" on it. HERE'S ONE
I guess the existing fused spur is just a single box, so you'll need to chop out the wall and put in a double box. It will need to be a deep one (at least 35mm as this type of switch is quite deep).
IMHO it will look pants. Cooker switches are designed to carry high currents and are very chunky. You'd be better off with a dual back box with an FCU and a single socket side by side.
Note these solutions only work if your existing point is not already a spur.
Capish?
I wouldn't do it that way - even if you fitted a cooker control unit (ccu) which didn't actually say "cooker" on it I would consider it misleading because that type of outlet is intended for a cooker.
As already mentioned the best way would be to fit a switch next to a socket, possibly in a dual backbox if you absolutely have to have them right next to each other. That is what a professional would do.
See pp 69-71 if you don't want the socket to be a switched one.
But I really don't get this:
You currently have a switch for the DW socket, and you want to end up with a switch for the DW socket and a new socket for the kettle. So you'll end up with a 2-gang accessory where there's currently a 1-gang, and you'll have to chop a bigger hole in the wall to fit it.
What's the big deal with just chopping a new hole for a new socket? (Apart from that being notifiable).
This is a plug:
This is a socket:
Despite many people using the hideous phrase, there is no such thing as a 'plug socket'.
This is a plug:
This is a socket:
I don't find "plug socket" anywhere near as bad as other phrases. The socket is for a plug, ergo "plug socket" isn't too bad IMHO. (the socket in which an eye sits is after all called an "eye socket") Far better than people refering to socket outlets as "plugs" :evil: now THAT is annoying and stupid.
Sparks can't take too much high ground on this when most use the disgustingly redundant acronym "PAT testing". :roll:
