I do think though that given the lack of understanding of electricity which your question highlights you shouldn't attempt any of the electrical design work for your new house....
I think you have your answer from the above.
If it were that easy everybody would be cooking using 1volt ovens.
You should be looking at stuff like ground source heat pumps and other sustainable energy technologies. Half an hour on Google should give you some options.
If you are using storage batteries for lighting etc then 12V or 24V lighting, TV, etc can be more efficient - the higher losses in the cable are less than the losses in an inverter running at low power to convert from battery to mains voltage.
However if you have a mains electricity connection then you use the grid as your 'storage battery' and if you use MCS approved kit and contractor you can get the feed-in tariff on self-generated electricity.
From an eco point of view, minimise the use of cement/concrete and steel, use local and sustainable wood for construction and fitting out, avoid plastic windows and chipboard kitchens and anything from China, and insulate insulate insulate.
The use of domestic energy for purposes other than heating/hot water is fairly insignificant.
