Hi
Just moved into new house and tested the rads but they are not getting hot.
The boiler pressure was at zero so i have re pressurised the system. The rad right next to the boiler is hot but none of the others are. I have bled the air from the rads too.
I have been under the floor and found that the flow is hot upto about 2 meters from the boiler and then goes cold.
So how do I get the system to flow correctly?
Also a lot of the TRV's were stuck in but think I have released them now as the pins spring back out.
Thanks in advance
Thanks in advance
