So are the branded imports, like Chint for example, OK?As for the others, apart from the unbranded imports which all seem to have have 3 letter names:
Keep the cover closed then, or put it in a cupboard and close the door.MK are all very well, provided you don't mind them changing the design of the circuit breakers all the time, so although the new ones may fit a board fitted last year, the levers don't line up and the whole lot looks an untidy mess.
If you're getting an electrician to do a rewire, or a proper job of a CU replacement, what % increase does extra for MEM represent?MEM are good quality but grossly overpriced.
Merlin Gerin?There are others.
I normally fit Hager boards, as they are good quality and not that expensive.
Wylex/Volex/Crabtree had their chance and failed big time - any factory which can turn out defective items for a full year must have no quality control at all.
Contactum were cheap tat even before they went out of business and were bought up by some lot from Saudi Arabia.
There are others.
No, the new ones have it along the top edge with the neutrals.Have the hager boards still got the MET down the left side.
