Hi Guy's. Not long moved into our new house and switched on the c/h for the first time. Problem. potterton ep2002 programmer and potterton boiler, honeywell thermostat. central heating will only work if the hot water is set to on. if i turn the central heating off the rads still get hot unless i turn the stat right down. Is this a wiring fault in the programmer?
The programmer is set to full pump which is where it should be. Any advise is much appreciated.
