What cable method is this.
27 Dec 2008
I have an installation with single wires run in plastic conduit,all conduit is chased in the interior blockwork and then re-plastered.
What is the"type of wiring"code and the "reference method"as required for the installation certificate to 17th edition.
Thanks in anticipation.
The second and third columns on the EIC are not completed(i)type of wiring and (ii)reference method.
Do you know what they should be for the installation I have.
This post has had 80 Views and very little response.Either because you can`t be bothered to reply or that you don`t want to or that you don`t know the answers!!
I have found out the correct answers I hope.
i)The type of wiring is code C
ii)The reference method is B
80 views really isn't that much, and I think you'll find nobody bothered that much because Chri5 already provided you with the correct answer to your question.
You're quite right - I can't be bothered to reply. Doh!
Well in that case, next time you have a problem try the screwfix forum, they have loads of incompetants advising other incompetants. :lol:
And ask yourself, does anyone really give a f*** about your problems.
Byeeee
PS It is also extremely unlikely that your wiring is as you described, but these guys will sort you out. http://www.screwfix.com/talk/forum.jspa?forumID=23[/quote]
What a T**T!!
