When we moved into our house, the fan in the bathroom did not work, so I decided to replace it. I ordered exactly the same one again to make it an easier fit and then went ahead to install it.
I have tested the 3 cables. There is one that become live when the pull cord for the light switch is used (switched live), one that is live all the time (permanent live) and another one which I assume is the neutral, as it isn't live. LOL
Anyway, I have wired it as per the instructions, but the bathroom light stays on, no matter what I do with the pull switch. The amount of light does seem to change slightly depending on whether it is on or off, but it stays on.
I have re-checked the wires in the fan and they are all fine, I have checked the light, and all the permanent lives are seperate in a connector block..........so somehow I guess the light is getting the live from the fan?
Or could it be something else?
