Hi, I have the German Combi in the subject heading, I had a problem before with the DHW which I solved by replacing the heat exchanger a year ago no issues until a couple months back when I lost CH,
although I was regularly topping up the pressure from the silver braided inlet
Today i took it apart needless to say to no avail, although I did get a thorough lesson in combi systems at least
I noticed something that I wanted advice on, I pushed the micro swith on the servo valve as far as I could to the anti clockwise (as if facing in the picture) and the CH outlet pipe became hot but there was a sound like crackling ( simliar to pouring cold water over a frying pan ) coming from the top of the hot water cylinder as if it was empty. Im at the conclusion that the cylinder wont fill and there for the it wont light up as theres no water flow. I have a feeling the cylinder being empty has something to do with the pressure drop
this is the switch I pushed against the spring force and got some heat with no water in the cylinder
Any ideas?
Any ideas?
