Hi Guys,
Just taken all the plaster off of the walls in our box room and was planing to dot n dab plaster board onto the brickwork instead of render and plaster again. Makes life much easier for a diyer. No sign of damp comming through, but once I've cleaned the brickwork as best as possible and applied a coat of PVA, could I paint the bricks with black jack, throw on sharp sand and then dot n dab? I don't really like using black jack (messy and permenant), so if there is another type of sealant, please let me know.
Also, a assume I can use a slightly thicker insulated plaster board on the outside facing walls, rather than render. I think I've seen plaster board with a moisture barrier, insulation and plaster all in one. Not sure how thick this is though?
