help needed with dead leg/air pocket plz
21 Sep 2009
Yesterday I was called to a house that had running water from underneath the bathroom floor, after removing parts of his newly fitted floor and furniture to gain access I discovered that a capped off piece of 22mm H/W pipe was leaking. This cap was on the end of a 2/3" stub out of a T-Piece that I assume was once used to feed H/W to the Bath before it was moved.
I cut this pipe T -Piece section out and drained out as much of the water as I could before rejoining with a new length of 22m copper and a couple of straight couplers. Problem/Leak solved.
Today, I receive a call saying that when the C/W taps are turned on, the boiler (Vaillant 824) displays the pump symbol and trys to engage the pump?
I have been told that this is a common problem when work has been carried out and an "Air Pocket" is formed via a "Dead Leg"?
The only other place I know of on the pipework where there may be a "Dead Leg"is a capped off C/W pipe that was next to the Hot that I had removed due to the leak. This capped off pipe is again on a stub about 2/3" long off an Equal T-Piece.
Has the removal of the H/W capped off section of pipework thrown an in-balance into the system?
How did the air get in?
How do I overcome this problem?
Do I have to lift up the floor etc again to remove the C/W capped off pipe?
Thanks in advance.
or just leave the system for a couple of weeks and the problem could go away. if not try a single check valve on the hot outlet.
Thanks for all your replies.
Spoke with Vaillant Tech and they said that I have to remove the "Dead Leg" as the air in the sytem is throwing the flow switch into thinking that H/W is required?
