yes, LSX is good $hit, but it is an irritant & is quite pricey. i use lsx on occassion when there is a tricky one as it does seem to work well, and there is a tube in my box, but i'll stick with me half kilo tub of jet blue for most things.
lsx may have advantages, but so does jet blue i can wipe that on with my finger and straight off my fingers onto a rag, no problems.
maybe i need to update, but for now it ain't broke so it don't need fixing
Yes, that's the way I used to do it, from tempering steel. I was assured by a guy, who had lots of old Brit bikes and raced them, that quenching was the proper way. It seemed to come out dead soft both ways.
I just tightened up a new 22mm copper olive fitting as tight as I thought wise (till it creaked slightly - I guess the olive tightening up), undid it and hey presto - I moved the olive round with my fingers! Is there any way of knowing when a compression fitting is correctly tight? To me the olives supplied with these fittings seem a bit loose on the pipe (before tightening), though the pipe is 22mm and the fittings say 22mm as well. Might try getting some other olives.
This is pipework for a concealed 3 bar shower, so rather not get it wrong...
Have actually had the yorkshire rep out on one job and he aggreed to replace all olives eith ones of a better quality as the cheap rubbish from china where not compressing onto the pipe causing several major floods on this job
