Since I started using PTFE on my olives, none of them have leaked.
Once Ive made a compression joint, I usually run a bit of solder between the base of the nut and the copper pipe. It can make undoing them again quite tricky. Dont get many leaks though.
Mr. W.
Mr. W.
You try getting a 42mm compression joint to exert enough pressure onto a copper olive to create a leak free joint without packing the olive with ptfe.
Mr. W.
Is this yours?
