Ok, whats the correct way to make this transition?
The plumber fitted a new boss and pipe rununder the floor, surfacing underneath the bath, all in grey solvent weld pipe, which according to the 45 degree elbow (has stamped on it) is 43mm pipe.
The bath and fittings etc are all on 40mm compression white pipe.
Do you have to 'stretch' a 40mm compression washer over the 43mm pipe, (looks like it would be pretty tight!), or is there some other 'proper' way to do this?
