I am at my wits end over what is going on with my heating system and could really use some advice.
We moved into this 2 bedroom 1920s cottage (concrete walls with unfilled cavity, 200mm loft insulation, all double glazed) three months ago and had been getting on ok with our old Ravenheat RSF820 non-condensing boiler, up until a week ago (which was still very cold) our daily gas usage was only 5/6 units according to the meter (I believe it is cubic meters) and our bill around £58 a month (we have no other appliances that are gas except the heating).
Now we have fitted a new condensing Greenstar 37CDi boiler from Worcester because we are planning to extend next year into a 4 bed house with 2 bathrooms. Now, I realise this is probably too big for our 2 bed house currently, but what is going on makes no sense. I have turned the CH thermostat down to 4/5 so the water inside the boiler heats to 63 degrees (the same setting as with our ravenheat) yet the room takes nearly 3 hours to reach 20 degrees when our old boiler only took half an hour? Surely this new boiler is more powerful and should heat the rooms much quicker? We also now see that our gas consumption has trebled since fitting although none of our timers have changed their programming and cannot see any obvious leak (have had the fitter round to do more checks) as the meter doesnt change when the system is off.
Does anyone have any ideas why this might be happening and is there anything I can do to lower our gas consumption using this boiler because I don't think using 14 units a day when we were using only 5 last week is even possible yet this is what we are facing?!
