My definition of a circuit is fundamental and universal. It applies to the 400kV and 275kV National Grid, to distribution from 33kV to 400V, to wiring installations in consumers’ premises and to electronic equipment. It applies to a.c. and d.c. circuits.
To reiterate, the current flows around the circuit. Wherever the current flows, that’s part of the circuit. Of course the circuit exists before it is energised and switched on. If the circuit’s d.c., electrons flow from the negative supply source, around the circuit at the rate of a few inches per minute and back to the positive supply source. Wherever the current flows, that’s part of the circuit.
Now, I did say unless otherwise defined. BS 7671 does define a circuit, for its purposes, as “starting and ending at the point where protective measures are connected.” Nothing wrong with that providing everyone understands that that definition of a circuit does not apply outside the limits of BS7671. In particular, the AD does not define a circuit and as BAS has pointed out, BS7671 is not the only standard that complies.
As for my understanding of legal documents, I’ll give an example: In a contract if you read the word “consideration” most people would understand it to mean something very different from what BAS and I understand.
Apart from the honourable exception of Prince of Darkness, it seems most of the regular contributors to this forum seek to interpret part P in a way that encourages notification. For a DIYer working in his own home and, if necessary, getting an electrician to test his work, notification adds nothing to safety but costs a significant sum. I think it’s proper to seek every opportunity to identify excuses as to why notification is not required in such a situation.
