When an old school tradesman turns up at your door I guarantee they have at least a brush and a dust pan. My tool kit includes industrial suction cleaner and a dust extraction machine. "Why?" is because I work within peoples home's.
By "back-to-back" the cable goes from one box to another (in PVC conduit is good practice) without going down and up...
Some of the homes I work on have 3 foot stone walls, but "sod's law" is that the joist on the other side of the wall is in the way of a straight down the wall cable run, hence "back-to-back" through a 3 foot thick wall could actually mean the angle I drill through at is one where the full length of my 5 foot long drill bit is just long enough.
I consider myself an electrical-mechanical installer (after a 20 year span installing goods and passenger lifts or undertaking the major refurbishments thereof in the South of England). When undertaking rewires I may also include automated gates or garage doors, whole home ventilation / heat recovery systems, X10 home automation / security installations, home networks...
10 Years ago I moved to a market town smaller than many council estates and with Hadrian's Wall at the top of the hill. Over the past 10 years I have undertaken industrial, commercial and electrical installation works (references on website for some of such), but in 2005 I was asked to aid a charity and assist resolve Electrical Regulation non-compliance issues on behalf of Flood Victims in Carlisle. 3 Years later I was still doing so and all the negative aspects provided issues which should be addressed prior to undertaking home rewires, especially rewires in occupied homes.
So... I have served my time up lift shafts and not as an electrician, but all you electricians know how much wiring is involved in the installation of lifts as well as the working tolerances of the mechanical aspects over 15 or 20 floors.
Whilst at college doing a BTEC I worked as a kitchen studio rep and then a kitchen designer. The first kitchen I designed for a wheelchair user was designed alongside the customer sitting in his spare 'chair, hence I become familiar with Universal Design concepts...
"House-Bashing" is the name given to house rewires by electricians... A good house rewire electrician must have an understanding of home construction and must be willing to go the extra mile to meet the needs of the customer.
First need: reduce disturbance to decor and disruption to household to the minimum.
Second need: reduce dust pollution and leave work area safe and clean at the end of every work period.
Third need: to trust...
Many good points have been made regarding my post and I welcome them all both negative and positive. Especially the negative. "Why?" Because in resolving the negative such becomes a positive!
Every home is different even though the construction of the home may be identical to others, but peoples NEEDS are different. The essential part of any rewire is ASCERTAINING those needs. If a customer rewires the underfloor area thermally insulated at the same time as the rewire, then a rewire provides a cost-effective time to undertake such. If a customer is considering a loft conversion, then running extra cables up to the loft for sockets, lights and smoke detector as part of the rewire is cost-effective. If a customer simply wants the loft boarded out for storage purposes the rewire provides a cost effective time to do such (and ensure all cables underneath are accessible via running in conduits from 50mm x 100mm trunking run along the eaves area of the loft).
Unlike industrial or commercial electrical installation works the domestic consumer wants a package deal and gone are the days when an electrician can say "I'm not doing that - it's not my job".
"There are many ways to skin a cat" is very appropriate to home rewires. I prefer to say "a rewire is a compromise between what the construction of the home allows and what its users require - the nearer we get to the latter the better the compromise".
On the basis I first fix 6 double sockets, an aerial outlet, a telephone point, a data point and dedicated lamp sockets in a living room in a day, the day is made longer by ensuring such are not knocked out of alignment by an heavy handed plasterer - there's no need when I can mix up a bucket of Bonding and make good around each back box to just below skim plaster level. Then make safe and clean up the work area.
The following day, if the home is occupied, I 2nd fix, by-pass the original sockets in the room where I've been working and remove the existing electrics. The new sockets are tested and run on a 16a protected radial circuit from a new consumer unit and this circuit will eventually become a 32a ring main when, for example, after the adjacent dining room is rewired.
"Yes" it is a lot of mucking about, but this is my Unique Selling Point (as a CEO up in the wilds of Cumbria says) and why customers fit in with my schedule as well as my fitting in with customer's schedules.
The point where shelving is located within an alcove is great - some see such as a problem, but I see such as an opportunity.
Whether your property is large or small, traditional or modern,
lighting is one of the most important yet most frequently
overlooked aspects of home improvements. (This is from my website)
A day's work can transform some dusty, old shelves into a focal point with a bit of imagination and the correct use of lighting to accent such.
Aesthetics and balance is of utmost importance and keeping everything in perspective vital to the overall customer satisfaction. I love it when neighbours pop in for a cup of tea near the end of the job and they say "Woww! Why didn't my electrician tell me about doing that...?".
My response to the above is "I'm not an electrician - I am an electrical-mechanical installer who specialises in home improvements".
Many electrician's poo-poo the room by room approach because, first and foremost, they want to make money as quick as they can. I want to make money, but every job I do leads to another due to "customer satisfaction".
As low as £17.50 per hour also has the travel element added, but still highly competitive with many local rates in the South and North of England. The hourly rate benefits those on modest incomes who cannot afford a complete rewire at a particular moment in time, hence a phased approach is planned. Each full rewire I allow 2 weeks to undertake and, if I complete ahead of schedule, I return home early. If issues become time consuming, I work extra hours to complete on schedule.
An example of a price quotation may be viewed at my website. With some electrician's charging £60 a socket or £60 a light does not fit into my pricing structure as some lights I install may have 3 switches, i.e., at either side of master bed and at entrance to bedroom with an additional switch for a reading light at either side of the bed too.
My partner is now making noises... It is now time to devote time to my own family and no further last post.
There's a difference between "house-bashing" and "home electrical installation refurbishment". If any of you have a NICEIC 17th ToolBox guide you'll see just one image of a person within and, fortunately, it's my back side.
