Hotpoint WF541 - pump broken?
31 Dec 2010
West Midlands
Hi there
My Hotpoint WF541 stopped working on Christmas Day. The error lights were 1,3,4 - in the book this told me a pump error.
So we took the filter out and found 4 coins, took them out, and hey presto - thought the problem was fixed.
Between then and now we have been doing our usual family washing, a couple of loads a day no problem.
However today the problem returned - exactly the same. This time the filter is empty. So.... we unscrewed the pump and found another 2 coins.
Put it all back together but still no luck - error message the same.
There is no sound coming from the pump.
Any help on the next steps would be gratefully received.
Regards
Is the pump wires connected at the back of the pump.
Test the pump with a continuity tester at the 2 connections at the rear of the pump. If it bleeps it's ok that means pcb shot. It it don't bleep pumps kaput
OK, so I went along to Maplins to get a continuity tester :)
Just tried it, and the black wire makes it light up - the red wire doesn't.
Regards
Claire
Put the tester on the two connections on the pump you are testing the coil on the pump. You will see what I mean when u unplug the wires from the pump.
Thanks for your reply.
Yes it lights up - so pcb gone?
What can I do next.
Thank you so much, much appreciated.
go for a recon pcb from emw 45 quid plug and play ,google them there in nottingham
