Hi there, I'm trying to undertake bleeding a radiator in my new place as its bubbling and not very hot at the top.
However there seems to be a problem. I can't find the bleed valve!
All the radiators in the house are the same it seems and they all have bleed valves in the same place. However this one seems to have a block covering where the bleed valve would be! Here is an image of where i think the bleed valve should be.
and an image of the other end of the radiator
Other radiators in the house have bleed valves like this
The metal square "cap" sticks out about a cm and is unmovable with a spanner. I don't want to use any more force as i don't know if its there for a reason. The radiator looks to be the same as the other radiators in the house.
Does anyone have a clue as to whats going on here?
Thanks very much!
Thanks very much!
